mleega1
OK, so here the deal. I have a 99 Ranger 2 wheel drive regular cab 3.0 auto 165,000 miles with a vibration felt only in the steering wheel above 70 MPH going uphill. It has had the following done prior to the problem and not because of it. New Ford upper and lower control arms outer tie rod ends rotors pads and wheel bearings tires balanced and front end alignment. Tires are about 60% good, this just started and drove fine prior.
The vibration can be pretty bad at times and is only when going uphill as I come to the top of the hill it starts to get less and down hill is smooth as silk. The hills are generally 4-8% grade. Under 70 there seems to be no vibration at all.
Thanks in advance for any help!!!
