Rangstang
- May 5, 2010
- Mesa, AZ
- My credo
- If it ain't broke, I can't fix it.
I made up a set of mount plates and set the engine on a pair of aftermarket 99 2.5L motor mounts. I had to throw about 3/8" of washers on top of the mount studs to give the 98 Explorer stamped steel oil pan about 1/8" clearance above the rack and pinion.
I then got the trans in and the crossmember under it for support and put in the stock 98 Explorer radiator, fan and shroud. Only problem is that I couldn't mount the shroud because it's rubbing on the fan blade. If I lift the trans tail housing enough to give 1/8" clearance between the fan and shroud, the oil pan is again touching the the rack. If I were to lift the motor higher and lift the tail of the trans higher, I will probably make contact with the trans tunnel.
Is anyone else out there with the coil spring a-arm Rangers having this issue? I checked the Mustang dual sump and it's actually about 1/2" deeper in the front so it would be an even worse fit.
Here are some pics below. Thanks for any insight you might have...
With tail housing on mount:
With tail housing elevated from mount and oil pan contacting rack:
