enola5930
- Mar 12, 2014
- Automatic
i bou.ght a 99 ranger with the 2.5 automatic and when you put it in drive it takes longer then it should(about 10 seconds) before it engages into drive and when you hit the gas it feels like it slipps a little. when u put in reverse it hesitates a little bit before it goes in gear but not as bad as drive. it shows fluid on the stick and says not to add any if its between the cross marked section. it has fluid on the lower part of the cross marked section about 1/16 of an inch. so im wandering if adding fluid might help and also what modeel trans. this is
