While I was working on the frame I had a thought about the rear suspension,want to get some feed back on this cool idea. I want to move the leaf springs under the frame and under the axle, then cut the rear part of the leafs off. Basicly I want to build a four link using the front of leaf as the lower link. I am thinking fo boxing the frame above the axle for strenght and adding 2x4 cross braces just ahead and behind rear end. Am removing gas tank to make room for true dual exhaust, will use a fuel cell where spare used to hang. Oh check out these mufflers from classic chambered classicchambered.com . I have them on my Dodge dd and love the sound. Am going to run them on the ranger but some with more aggressive sound. My adhd kicked in again, what do you guys think about my suspension idea? I think it wil be cool plus I still don't color between the lines( or drive between them either).
Using the springs as lower links doesn't sound like a good idea to me. I think they would have too much flex, and wouldn't help keep the axle located as well as a more solid link would.
Thanks diesel it does give me something to watch for as I build it. As for flex I'm counting on it giving some to help soften the ride a little. Locating the axle is going to be the panhard bar. I have seen a system like this on the net figured I would try it. It will work or it won't then I can always build some solid links. Just to clarify when you say flex you mean up and down travel, or rotational flex?![]()
btw, chrome says my valve covers will be done next weekI was going through the pics from the other day and I'm embarassed my shop was a pig pen. We normally clean some at the end of the day but nothing like a pic to show the crap.
But the ranger was getting attention so alls good
This is the kinda thing I was thinking, but with the spring on the bottom.
