backroad101
- Dec 26, 2009
- Automatic
So I bought the OEM style fog lights and lower valance that you see on ebay for around $40 a piece.
Foglights mounted just fine. Plugged them in and just need to mount the switch and see if I need to add a relay and/or fuse
The problem I ran into is when installing the valance. Is there a trick to getting this piece on?? It seems to be a half inch short of it lining up. When I started on the driver side, the pass side came up short and vice versa when I started on the pass. side. Right now it is sitting with it not bolted up and flapped open on the the driver end.
Thoughts?
Thoughts?
