99 fenders,hood & headlight header
94 lngbd
Lakewood,Wa
I have a 94 ranger & was wondering if all the front end body parts from a 99can be swapped onto my truck?
As far as I know, you just need to swap the core support and whatnot on. Some holes will probably need modification though. I have plans to do this to my 93 for an Edge front end.
search lol
to swap to 98 you need the 98+ radiator support to drill new holes for the body mounts, and then the fender from 98+ and etc will bolt on.
bumpers you have to make a custom mount to mount 98+ ranger bumper on a 93-97
with a 98+ radiator(98-09 all the same) support on a 93-97 you can upgrade to a 98-09 ranger frontend
I did do a 98+ front end sheeet metal swap search & nothing showed.
Are you 2 referring to the actual metal radiator core support or the fiberglass headlight header section which bolts to the rad.core support?
