99B4000_4x4
- Mar 8, 2009
Im having a problem with my battery light blinking. It does it at start up, and then it will idle just fine with the battery light off. But once I rev the motor the light will blink on and off randomly. If revved at about 2500 rpm it stays on constantly. I checked the battery cables and they are actually corroded pretty good. Does that mean the cables are bad or that the alternator is going out? Or could the corroded cables caused the alternator to start going out? In which case both would need to be replaced. Any help would be appreciated. Thanks.
