Xanthos2008
- Oct 12, 2008
- Automatic
I have the slow rolling abs kick on issue. When stopping around 5mph or less the abs kicks on. Its not the rotors like i have read in other posts. I see people saying to clean the abs sensor. My question is how? Looks like the sensor is built into the hub. There is a allen bolt there so does this sensor come out? There is no abs light, no fault codes, i beleive it just needs cleaned or something. I also read something about checking the ohms. I checked both front they are sitting at .42 on right .44 on left the back center is sitting at 1.91. No idea if that helps. New brakes. new rotors, no air in the lines, replaced rear wheel cylinders
