kevinmcgowan25
Hi all I am looking for some serious advice. Currently having an overheating issue, all cooling system components have been replaced by me and are functioning properly. Passes the glove test but is blowing off the top radiator hose. Plan to run truck to operating temp with no cap then try the glove test, cold there is no bounce. I recently changed the timing chain sprockets and guide. Decided to run a compression test to try and find something to work with. bank one all cylinders came up 120 cold and dry. bank two 4=105 5=95 6=120. Then I put some oil in number 5 and it shot up to 150 haha. Bad ring maybe? Wondering do you think I could be off a tooth on the chain. Truck already has aftermarket heads. The truck runs and drives normal, idles fine develops what seems to be a single cylinder miss once it gets hot and starts to overheat. Ive been very careful the trucks gauge has never been past 3/4 and it does work properly had issues previously with the sender but have fixed. The truck has no o2 and is straight piped with 2.5 pipe dual exhaust idles about 1000 cold then drops down a bit once warmed up. I have already rebuilt the entire frame and cab so I plan to keep the truck regardless. I have a leak down test.
