float89
- Apr 17, 2017
Im a little lost here. The ol ranger developed a miss and hesitation. It's a 5-speed and Under load at low RPM it will trip up a little. Not completely fall on its face but start missing and has noticeably less power. If I stay out of the gas and accelerate moderately thru the gears everything is fine with maybe a miss here or there but power is good and life is great. Although if I try to accelerate fast and get on it, the thing really starts missing and falling on its face. Not to the point where I cant continue to increase speed but a lot of jerking and lurching. Back of the throttle and I can cruise at any speed with no issues. I have ran about a tank of gas thru it since it started and i have not seen any decrease in mileage which I suspected I would.
Not sure if this is related or just a coincidence but this all started suddenly after one morning with a troubled start. I did the whole not turning it over long enough and it didn't start. It was as just about to fire up and I let off the key to early and it die. I have done this before and no problem just try again right? Well when I tried the second time it just cranked for a few seconds with nothing. tried again and same thing. finally, while I was cranking I gave it a little gas and it started to fire on maybe one cylinder, maybe a half a cylinder... I let off the key and it slowly started to pick up the rest of the cylinders but continued to run a little rough. Let it idle a bit but I knew it still wasn't right as in a little miss on idle and then off course all the above symptoms from above.
It just seems odd to me this came on so sudden after the starting episode.
I did the simple stuff.
- Injector cleaner
- New fuel filter (what an absolute PAIN!!!)
- Air filter
any suggestions would help.
truck as 110,000 miles.
OH, and no codes...
- Injector cleaner
- Air filter
OH, and no codes...
