lithiumbomb
- Oct 25, 2015
Stay with me, throwing in some background first.
I've got a '98 Ranger that I acquired a few months ago after it had spent most of the past two years sitting idle. One of the problems I'm tackling is the ubiquitous rear window leak, which has made the interior smelly and stinky.
Anyway, as perhaps a side effect of the cab being damp for quite some time, most of the unpainted metal in the cab has some surface rust.
So, to my actual problem. The brake pedal doesn't always return to rest position. It will get most of the way, but the brake lights stay on, and you can tell the brakes are dragging. Pushing in the clutch allows the brake to return, or I pull it up with my toes.
Any hints on what to do here? The best I can guess is I try and get some grease into all of the moving parts in the pedal box. I'm sure it can be taken apart (I see a bushing or two in there) but that doesn't seem like an easy task for non-contortionists.
thanks
thanks
