98 explorer to 99 Ext Cab
nyyanks
I have a 99 extended cab witht eh 60/40 seat.
I have access to a 98 Explorer. My question is will the seats fron the Explorer work in my PU. What would be involved, tracks from PU onto buckets or Explorer tracks will work just bot in.
Also the buckets are electric are there likely to be plugs in my PU that I can use if not how much work is it to make them work.
Any help will be greatly appreciated, thanks
They should just bolt right in. My 92exp seats are the same as my 91 rangers were.
For wiring, i looked its only power lumbar on those right? The diagram I have doesn't show anything else. Anyways wiring shouldnt be to difficult it looks like a simple power connection off of an 25 amp fuse ( slot 18 in your fuse panel ).
Hope that helps
