Darren94
I picked up a 98 b2500 with 179k and i have noticed that when i let of the gas and let the truck coast in gear, there is a consistent humming sound coming from the trans. The noise is louder with higher rpm and quieter with lower rpm. It also seems to occur in all gears but is most noticeable in 1st, 2nd and 3rd. However, if i press in the clutch, the noise will always stop.
The previous owner recently had a new clutch, TO bearing, flywheel and slave cylinder installed and i did notice that the TO bearing is a bit loud when idling.
Any ideas? (i changed the fluid and there was a small amount of filings on the plug but, the fluid looked clean)
