NoDangerIfItsARanger98
- Aug 17, 2017
- Age
- 29
- Sandylake PA
- 4.0 V6
- Automatic
- Total Lift
- None
- Total Drop
- None
- Tire Size
- 245/75R16
I have a 98 Ford Ranger that I just recently rebuilt from inside out.
Long block, all new internals all tested ready to roll.
Almost everything on this motor is brand new. For the first 500 mile break in I ran it at different speeds under different loads with no issue. Change oil, Repeat.
At 1,000 I changed oil again and repeat.
It has a little over 2,000 on it now and I just changed the oil to what I'm going to run with to the usual 3,000 oil change.
When I got the truck out of Texas I put new plugs and wires and fuel filter and what not in it and had no issue. I put 10,000 miles on it before a rod bearing went out (long story) as it had 224,000 when I got it.
Now even before I did a rebuild I had issues keeping plugs in the thing I was changing them all the time maybe 2,000 - 2,500 miles in a set. It always had O2 codes and no matter what I did I could not fix it. It would run just fine without any missing or any fuel smell even with the codes. Then it would start out of no where and I'd change them and repeat.
The new motor has been fine until now it started missing a bit and on deceleration it would rev up and down between 1500-2000 rpms. It runs perfect until it's at operating temp and the O2s kick on and then it feels restricted like it's pulling tons of air but there's no power behind it unless you floor it.
I pulled the codes on my scanner and they are reading rich passenger and lean driver.
Two of the sensors are reading between 1 and 3 milivolts and one is reading up on the 900 + milivolts.
Is that normal or is something shorted or what?
So this time I bought new plugs, new coil pack, 3 new sensors, and new cat. Still same codes and still same issue
The old cats the first was half melted and the second was plugged with soot.
My question is where do I look next? Is it something stupid I'm over looking? Anybody else have this issue? I need to drive it quite a ways this coming Monday and I can't with it running this way.
