NoDangerIfItsARanger98
- Aug 17, 2017
- Age
- 29
- Sandylake PA
- 4.0 V6
- Automatic
- Total Lift
- None
- Total Drop
- None
- Tire Size
- 245/75R16
Hello I'm new here but have lurked for a long time. I have a 98 Single cab long bed Ranger with the 4.0 ohv in it. It's my daily driver and I love it. Its a rust free southern truck I bought out of Texas with 200,000 plus on it. The truck made it 10,000 miles for me before the engine developed a severe knock. Pulled it apart and could tell right away it had been abused all it's life. Long story short I bought a long block with all new internals and rebuilt the rest myself. New injectors, gaskets, the works. I followed the break in process to a T and everything ran fine when I first got it back on the road. Changed oil after the first 500 miles then again at 1,000 and switched to a heavier oil since the oil pump doesn't like the thin stuff. Anyhow after a few days in it felt sluggish so I checked the air filter and low and behold the mice chewed it to pieces. It sat out behind my place of work for a month while i waited on parts so I should have known better but I was just happy to have it up and running again. So changed that and the changed plugs as they were fowled pretty bad from the lack of air for a proper mixture and didn't have an issue. A month or so later I developed the same miss or more so like a lag or lope. Checked everything again and all was fine. Decided to check the cats and the first cat was melted 3/4 of the way shut and the second was plugged almost solid with soot. So for a quick fix I( dun dun dun) removed them and instantly gained my throttle and power back. I only drive it to and from work maybe 8 miles a day. Didn't have any issues again for a while. Now this thing has had O2 sensor issues from when I bought it and even after I rebuilt it it's always throwing a lean code for one bank and rich for the other. I've changed sensors and used cleaners and seafoam and the whole 9 yards but it always only works for a short time. I can not keep spark plugs in the thing and the O2 sensors are always bad. Just a week or so I again developed a miss or more so like something is restricted, like it's taking in all the air it can but there is no power in the the throttle. I also found the hose coming off the intake to the what I'm assuming is some form of vacuum canister or something with the egr was collapsed and as soon as I opened the hose it almost stalled itself out before regaining idle speed. I guess my overall question is where do I go from here? I'm not looking to make my ranger into some hotrod power demon, I just want it to run as best as possible for what it was designed for. Light duty work, 4x4 for the winters and the occasional offroading and overall smooth running engine performance. So questions are do I put a new cat on and change the O2s and hope for the best? Different muffler for better flow? Fuel system upgrades? or is there another issue with the egr and vacuum systems? Are there any things you all would recommend or suggest? Thanks for your time and I hope I haven't rattled on to long ?
