okay So I dropped in a 97 Exploder 4.0 and trans in my 98 Ranger. The two issues I see right away
1.) The headlight harnesses on the truck does not exactly plug into the headlight harness on the motor. On one the plastic connection block is square, the other is alsmost rectangle. Should I get a new headlight harness and bulbs or take the connection block from another Exploder and run the wires into that?
2.) I see 2 fuel lines coming off the 4.0 and only 1 running from the tank. Did the Exploder have a different setup? Whats the solution?
Headlight harness
Fule lines
Headlight harness
Fule lines
