nestico18
- Jan 12, 2015
Hello everyone, well i'm new to this forum. I figured this is the best place to come for specific help on this subject. I have a 98 2.5 with a 5 spd. Has about 155k on it. I had someone read the codes for me and the three i have listed above were pulled. 1506 is i believe high idle, The typical hard to figure out 1401 DPFE, and 0303 which is cyl 3 mis fire. I love the truck and is my everyday driver to and from work everyday which is 45 minutes one way so i need to get this problem solved which is why I started my own thread compared to looking through every single post and trying to narrow it down. When i start my truck it sounds like its missing and idles rough. When you rev it up in neutral it seems fine. In gear pulling out it feels like it hesitates and bucks like it doesn't wanna go anywhere. I dont understand it. Also it seems like it wants to stay idling at about 1200rpm which seems higher them normal. I know a lot of people have this problem and replace a lot of different things and still can't figure it out. Does anyone know if some of these codes are related that one problem is causing all three codes. I have brand new plugs and wires on which are all motorcraft. I'm hoping someone can steer me in a more specific direction. I'm not a mechanic but i'm not stupid either. I had a problem with this truck before and ended up pulling the motor and had to put a reman cylinder head on it with all new top end gaskets and it ran just fine after that. I did all the work myself so I would say that I atleast know how to mess with things enough to get by. Hope someone can help me out. I need to get this fixed being it's my only vehicle.
