Joey_deluca
- Sep 19, 2013
Ok so here's the deal. I have a 1998 ranger 2.5. Has 107k on it and I have a misfire issue. It was running great then started misfiring really bad out of nowhere but would clear up and act like nothing was wrong. Then come back and misfire at a red light, but when I go it would clear up around 20-30 mph. Now I thought this would be a simple issue and have exhausted all of my knowledge and many others to try and fix it. Here's what tests have been done and what was changed.
Compression test - returns good at 175 psi
Leak down test - results good less than 10% drop
New wires - ohms within range
Another new set of wires - again within range
New plugs - gapped and recheck multiple times
Checked coils - ohms within spec and firing on all but cylinder 1 on rear most coil pack
Swapped coil pack - nothing changed
Swapped injectors - nothing changed
Noid light on all injectors - pulsing constant
Smoke test for vacuum leak - no leaks
Now I'm lost, I ran out of ideas on what to test next. I may be forgetting something that I did as another test but I'm open to any ideas. If someone can give me a clue as to what it could be. Thank you
