tab a
- Oct 22, 2016
- Automatic
I replaced a bad 97 (4L) transmission with one from a 98 (3L). Both 5R55E.
Speedo doesn't work and shifts aren't quite right because the 98 transmission doesn't have the VSS on it.
I believe I need to get the VSS signal from the rear diff ABS sensor, to the PCM but am not sure how best to do this?
Putting the 98 GEM into the 97 didn't change anything. And the engine really didn't like using the '98 3L PCM in the 4L '97. I presume because of the different engine sizes?
I'm GUESSING if I put the 98 wiring harness, and GEM into the 97, and got a 4L 98 PCM all would be well? But, is there an easier way? Splice ABS diff signal to 98 GEM? Would 97 PCM be ok with that?
Thanks!
Thanks!
