can u swap in a 4r55e or 5r55e 97 tranny replacing a a4ld to a 92 4.0l ranger cause i think i should of done that instead of rebuilding the a4ld and putting new heads on the 92 dohc 4.0ll
obd1, obd2 not compable w/ eachother, 4r44e is full elecrtonic w/ lockup, a4ld is only lockup. computer, full wire harness, some engine sensors, gauge cluster, im shure im forgitting stuff.
your call, but i think you should fix it, not replace it.
A DOHC 4.0? Good one. If you already rebuilt the A4LD, you might as well run it till she blows. If you take good care of it (fluid changes!!), it should get you over 150k.
For
