T/S #25
- Sep 13, 2011
- Automatic
What are most of the guys using for their clutch set-ups? Cable or hydraulic? I am trying to help a friend out with a problem he is having with a truck he just bought. The situation is this: When you press the clutch pedal, the clutch doesn't disengage enough to shift the transmission. As far as I can tell, whoever did the 5.0 / T-5 install left the factory 4cyl hydraulic clutch parts in the truck(reservoir, slave cylinder, lines, pedal, etc). Any help or direction with this problem would be greatly appreciated. I will also continue to search the message board for ideas/pictures to assist with this problem. Thanks in advance for any and all help.
