fuledya
- Nov 11, 2009
- Automatic
My drivers side power window rocks back and forth while rolling it up and hangs up. I've pulled the door panel off. I need to replace the plastic bar, that the door actuator rides up and down on, as well as the plastic bushings that ride up and down on this vertical black square plastic bar. Does anyone know what these pieces are called, I've tried searchin on ebay with no luck. One last thing, the black plast square on the end of the actuator, it swivels on the ball on the end, is that replacable? I need to get all the slop out of the window. If anyone can help it would be much appreicated.
