97 Ranger 2.3l stalls coming to stop
sschlager
1997 Ford Range
I just changed the tps and valve cover gasket. To change the gasket you have to remove the throttle body.
I put everything back together but noe it runs rough, stalls when idling. It also stalls when your driving and coasting or put in the clutch to stop. While driving it runs as smooth as a baby butt.
The only thing I was iffy on was the rubber line connecting to the bottom of the throttle body. It doesn't look like it is in all the way.
Does the aic need to be reset?
did you clean the idler air control valve and check the runner control solenoid hoses?
Why did you change the tps? Check for vacuum leaks? Everything plugged back in?
