timingchain
Hi all,
I've got a 97 Ranger 2.3l (manual). Truck starts rough, idles poorly and acts fuel starved. A few minutes after first starting it will enter closed loop and if under load/throttle opened to more than ~2300rpms, it will stay in closed loop and run quite well.
UNTIL I'm at a red light, or idling for whatever reason. For a couple minutes its ok, and then it drops out of closed loop and runs poorly, and it will not go back into closed loop until... it feels like it--I've gone 30 minutes cruising down the highway, underpowered, until it decides to enter closed loop again.
Codes: p0170 lean and p1151 HO2S not switching.
I've got a scan tool on it and have noticed that when in closed loop the o2 sensors are responsive and switching. But as soon as it's at idle, they both go to 0v flatline (upstream and downstream always drop out/come back online together). For the next couple minutes I can rev up the engine and they will respond. Also, if I slowly step on the throttle, at around ~2300 they start switching again. If I slowly let off, they go right to 0v as soon as I drop below 2300rpm.
Once it drops out of closed loop, the o2 sensors stay unresponsive and it doesn't seem to go back into closed loop until I restart the truck. I haven't had a scanner on it long enough to tell if the o2 sensors start sending voltages again, but I suspect that's the case.
I have tapped into the o2 circuit at the PCM and the voltages are the same as those seen through the scan tool. The upstream o2 sensor is new, I've bench tested old and new with a propane torch, they both work fine. Also, ohms across heater circuit is within specs.
I've tested the TPS: 5v ref, <.2 voltage drop to ground. I only have a digital voltmeter to test the signal circuit but it seems to be sweeping smoothly and voltage readings are between .8 off throttle to 5v WOT.
New fuel filter (old one was one of the dirtiest I've ever seen--runs much better under load now). Fuel pressure is perfect, between 30-45 psi and no drops while quick revs. Stays solid at 45 when vacuum line pulled off regulator.
STFT is below +10% most of the time (scan tool I was using up til yesterday didn't show long-term). It shoots to +30% at idle though I haven't found a vacuum leak yet. I intend to replace the PVC (even though it rattles) but they were out of stock. I couldn't see it causing my main symptom, though.
What am I missing?
Thanks in advance for taking the time to read this.
What am I missing?
