rangebob
- Aug 30, 2015
I popped my timing belt the other day. I've been trying to get it back on and lined up. Yesterday I did it for the 3rd time and it was running and idling with no problems. Went out and did a few things and it never had a problem.
Today I started it up and the idle is running real fast. I pull everything apart again and the camshaft sprocket was a tooth out. I fix it again and run the belt around and I can feel that the oil sprocket feels like it is dragging on the plastic. After I put the belt on it does drag and at times jumps on that sprocket. I've made sure that the belt was on tight. I did get a new tensioner for it and that doesn't seem to make a difference.
