snab07
hi all. i am looking for some wirng info on mating the 42 pin connector of a 97 explorer 5.0 with a 96 4.0 ranger chassis. the only two major differences i see are that the explorer has a fuel tank pressure transducer and the ranger does not. also the explorer uses a vapor managment valve for the evap system while the ranger uses a purge valve and purge flow sensor. if any one has any info on how to get these two harnesses to play nice it would be much apprieciated because in my state a check engine light means no inspection sticker for you.
