- Nov 10, 2009
- Manual
My 97 2.3 supercab quit charging last Wednesday. Unfortunately I was 20+ miles from home when the battery light lit and the voltmeter needle dropped (BTW do these trucks have real volmeters, or crappy on/off switches like the oil pressure gauge). Didn't make it home, and the flatbed tow was $120.
After checking fuses and the A terminal (battery) fusible link, I made a bad guess in replacing the voltage regulator and brushes to the tune of $50. Nope. Took the old alternator to Advance, and the diode pack was gone. OK, that explains why it went suddenly.
Bought the new Remy for $180, and damned if it still isn't charging. Low gauge, battery light is on. Connections are clean and tight, plugs aren't corroded or burned, I'm running out of ideas. I did not check the I and S circuits. I guess I need to. Is there some common charging problem on these things I'm overlooking?
