97 3.0 question
Focklerx33
Belleview Fl
i have a question i did a motor swap. my question is on the back off the motor between the 2 heads on the 3.0 was a thing for plug in idk where the wire is for the plug. here is a picture. idk if the plug is in the wire harness or where it is thanks. also would like to know the correct name for this part
well can you tell me if the wires are with the fuel injectors or is it in a different wiring harness
well the wiring harness had the three prong set up so i had to replace the entire thing
