Boomers13
I've been trying to solve my cam sensor issue for the last month with no luck at all. Replaced the sensor, ecu, and rewired the sensor and none of it worked. The only other thing I can think of is the fact I have an engine from a mustang. I found a 2.5 at the local pull a part in Louisville with around 150k on it compared to the 230k+ on all the 2.3s. Since it seems like a fairly simple swap I figured I'd go for it. I plan on pulling the engine, harness, and ecu and swapping everything over. Is there anything else from the 98 that I need and other than the fuel rail, what else do I need to use from the 2.3? This is my first engine swap attempt and any help will be greatly appreciated.
