I have a 97 2.3L 5 spd. ext. cab ranger that is having an rough idle issue for the past month. When the engine is cold and I start it up it runs fine when the high idle is on. Once the rpms drop down to about 800 after it comes off high idle, it idles rough. After the engine gets above about half way to normal operating temp. it will idle fine. So far I have cleaned the throttle body and the IAC, I put new plugs and wires on about 3 months ago. I did have a code for a misfire on cylinder 1 when it first started doing this. I cleared the code and it has not came back on since. Would the power steering pressure switch make it idle rough if it is faulty?
