roughranger
- Oct 25, 2007
ok guys i let my truck sit for a few months and got in it started it up and ran fine then i got in a few days later and went to let out on the clutch and it didnt do anything clutch came up fine but no go go. so clutched it and it only went down half way then get real hard and when i let back up again it engaged and then wouldnt disengage again you shut it off let it sit for 30 seconds then it will work again. i am thinking that where the clutch slids it is hanging up cause it did sit awhile b4 i got it. is there a way to lube that without dropping the whole trans or do you think it is something else thanks guys also when you first start it and go its fine doesnt do this till after it is warmed up and it is full of fluid in the resivor
