cbarnes0061
OK so I have a 96 ranger with the 2.3 and is 2WD. I occasionally while driving will have first my park brake light come on then it goes off and the ABS light comes on and stays on. Always happens when the truck is braking. Cut the truck off and fire it back up and the light goes away. I had this happening for a while when I found my right front wheel bearing had gone bad. Replaced both front rotor assemblies. This caused the light to go away for about 3 months and now it is starting to happen again. Already jacked the front of the truck up and checked for play in the wheel bearings thinking maybe I did them wrong but no dice everything seems nice and tight like it should be. I have read there is a connection under the truck on the drivers side that sometimes gets corrosion in it and I will check that when I get home from work today. Just wondering if there is anything else I can look for while troubleshooting this.
