chainbreaker2012
- Feb 12, 2017
- Havana florida
- 4.0 V6
- Total Lift
- None
- Total Drop
- None yet
- Tire Size
- 225/70r15
ok engine was missing on #1 cylinder did all the normal stuff plus a timing belt. due to it being old and don't know when it was last changed. ran truck for a while and once it warmed up enough for thermostat to open I noticed a lot of white smoke pouring out of exhaust along with water. It did not smoke until it warmed up.long story short I did compression test and got 60 psi on #1 so I pulled head but can not find any place on gasket or surfaces where I could be loosing compression or where water has been coming into the cylinder. I did read something about the valve seats recession into the head and am curious as to hearing more information about this. I flipped the head on its back and filled the valve area with Gas and it didn't leak at all. did same with the cylinder and no leaks their either. I did however notice that there is a lot of carbon build up on the head and I figured if the head was cracked then I would see a clean area around the Crack where the water coming in would basically steam clean it. a pressure test of the cooling system showed no leaks aswell. sorry for the long post but I'm lost at this moment.
