thought I had a water pump going bad.....replaced water pump and timing chain. after getting her all back together still have a squeal (replaced tensioner, chain, water pump,....about a year ago replaced the alternator.
Question: could the cam synchronizer be the culprit?
also the engine "hunts" (idle is up and down - not steady and smooth).
when I try to turn the steering wheel (the engine drags down) could I have missed a tooth on the timing chain and if so,
Question: Do I have to open it back up?
Will check back in the morn
Thanks!
Thanks!
