fireant
Hello,
Today I experienced the dreaded problem of not being able to shift out of park and no tail lights. I had my trailer on at the time.
I managed to get the trailer and truck home by turning it off and then to accessory, then using neutral gear to start from.
So I checked the forums and followed all the leads I've found so far, but I still havent got it nailed down.. can you help?
What I've done:
I dont really know what else to look for... from what I've seen the switch is good and the fuse is good...what's next?
Thanks for reading!
What I've done:
- Replaced the #10 brake interconnect fuse (7.5A)
- Cleaned brake pedal switch connections with De-Oxit
- Removed the trailer lighting harness and reconnected to the factory configuration
- Removed and tested the brake pedal switch for continuity when pressed - it tests good, so the switch is ok
- Tried to bridge the connections in the brake pedal switch harness with a wire, but no lights
Thanks for reading!
