AlwaysOnKill
Can you use them in a 2nd gen swap ? If so what motor mount would work best ?
Forget anything about the Explorer plates in a pre '98' Ranger, just use the common Mustang mounts everyone suggests. Pretend the Explorer motor is just a 5.0 Mustang. Frames changed in '98' as a lot of things did.Can you use them in a 2nd gen swap ? If so what motor mount would work best ?
Thanks ! Do the mustang mounts allow the engine to sit low ?Forget anything about the Explorer plates in a pre '98' Ranger, just use the common Mustang mounts everyone suggests. Pretend the Explorer motor is just a 5.0 Mustang. Frames changed in '98' as a lot of things did.
Dave of the Nord
