roycet4
- Mar 10, 2009
For the last two days my son said his steering wheel in his '96 4X4 has be "jumping" to the left and has to forcefully hold onto the steering wheel. I was expecting a low tire or dragging brake caliper but when I drove the truck the steering wheel would almost pull out of your hands and turn left. The best I can describe is as a lifter being at the peak of a camshaft and as the cam is rotated the lifter falls rapidly down the profile of the cam. When we jacked the front end up and I had my son turn the steering wheel and the tierods looked fine but when the wheels start move off center you can see the front axle U joints bind up and then jump (rotate) and at the same time you hear a slight klunk. The truck has 193K miles,we've had it for the last 50K so I'm guessing the U joints are bad. I do not think its the steering box.. Also this is happening with the axle UNLOCKED (have Warn hubs) so when I spin the wheel the axle does not rotate.
Any sugestions?? If I pull both axle shafts and replace U joints, is that a day job or weekend job??
Thanks
Royce
Thanks
Royce
