logsaw
- Feb 20, 2015
This vehicle came from Minneapolis and had a hard life there in the sodium chloride. The 5 spd truck went to a local shop to replace front engine timing belt, idlers, front seal and the like, for preemptive work. Prior to that, I personally replaced all sensors except for crank and cam sensor. Shop also replaced crank sensor. I had also replaced rear coil pak, wires and plugs on passenger side and fuel pump. After my initial work on it, the truck ran great, good power and all.
I take the thing home and discover it now idles somewhat rough and has no power if I tromp on it. I have the exhaust partly down as it needs replacing. I thought possibly the interior of the large oval muffler may have collapsed, building back pressure. I slip a good opening in the muffler, but still the lack of power if tromped on. The catalytic converter was also removed for the exhaust work and test, thinking it might be bad and building back pressure.
I ordered a new coil pak for the secondary ignition on the drivers side along with plugs and a cam sensor.
I tested the rail fuel pressure which read 37 - 42 lbs.
So what is the problem????? Could it be the shop got the timing belt somewhat wrong?? I appreciate the input. Jay
