- Oct 24, 2019
- rochester, mi
- Manual
- Total Drop
- 2"
- Tire Size
- 315 /35- 17
- My credo
- Always bite off more than you can chew!! :)
Hello to all, hope everyone is stayin healthy!
So, pulled out my leafs and axle and replaced with a ladder bar with coil overs, 07 -8.8, and the rest.
Didn't think to take a look at the parking brake set up, just tore it out. I've ordered and received a Dorman middle cable, right rear and left rear cables. The front cable and brake pedal are intact so I'm just going to reattach to the original front with the new parts. I can figure out how to mount a bracket to secure the passenger side cable (with the prongs) but I don't have a clue how to hook up the drivers side cable to that to make them pull together??? Also, the mid cable I got from Dorman is like 3' too long (4' total length) and appears to be almost unnecessary! I have a standard cab, (short wheel base). I've looked at diagrams on line but I'm not seein my set up. Do I need a 2 hole bracket or a special equalizer coupling or something?? The drivers side cable has the slug(?) on the end of the cable that would go into one of those couplings. Any help is appreciated, a picture would be awesome! Thanks, Jack
