5.0 4x4 manual swap in 1998 ranger
Jbyrd
Cohutta
GA - USA
Vehicle
Drive
Stock
Stock
Ok so I need some help im looking to swap a built 5.0 engine into my ranger i thought about using the 4.0 4x4 trans but I heard it won't handle the power of a built 5.0 what trans will hold the power im also wanting to keep my truck manual any advice?
Do a search here? Visit the tech archives? This has been discussed a ton…
The 4.0 trans will not bolt to the 5.0/302 block. So not only will it not handle a built 5.0, but it won’t bolt up without adapters.
How built of a motor are we talking anyway? You just say “built” which could potentially mean anything from headers/cam/flow port/etc to something capable of 800+ HP.
If you’re building 800+ HP you’re going to want a ZF5 or something not common to swap in. The ZF5 will require a body lift and/or trans tunnel clearancing.
If you’re building more stock, the M5OD from a 97-03 F-150 with the 4.2 is what is usually chosen.
I would like to get at least 400 to the ground hp wise
In order for Ford engineers to get 400 engine horsepower out of a 5.0 Coyote they needed 11:1 compression and 6k rpms.
To get 400hp at the ground you need another ?75? hp at the engine?
A 5.0 Windsor with >11:1 compression will need premium, if not racing fuel; a 7k rpm power peak will leave it no fun to drive around town. And the stock Windsor block will split in 1/2 at that power level.
An a ZF/M5OD-R2 aren't designed for working behind an engine running those rpms.
