95 Ranger Disc Brake Dust/Splash Sheilds
mxboy349
Anyone have a source for 95 Ranger 4x4 Front Disc Brake Splash/Dust/Backing sheilds? I cannot seem to find any listed anywhere.
I looked awhile back and had the same luck - ZERO.
But then again, I'm a rookie and prolly didn't look hard enough.
Mine are toast and would love to find replacements.
Did find some HERE, but they are "unavailable."
I moved this over to the Brakes forum.
I know I did a wheel bearing on my 06 about a year ago and they were looking rough then. I'm sure I will need a set come spring. I haven't tried to find them.
I'm sure you tried LMC?
I moved this over to the Brakes forum...
I did not until just now> No joy, but thanks for push 😬
Temporarily
Out Of Stock
No Backorders
well damn...
it was worth a shot. Anything at the junk yard here... is probably just as bad as what I have.
They also serve the purpose if directing cooling air onto the rotor. I feel they're worth trying to find.
I'm running into the same issue with my 2011. One attachment point on both shields is busted. No one has them in stock. As thin as the metal is, I don't think welding is a solution either. This whole supply chain thing is a bit of a problem.
I'm doing a full front end rebuild. Radius Arms, Ball Joints, brakes, everything. It was super rusty under there, one of the backing plates had rusted away and came off a long time ago. Be nice to put some back on there but if there're not available then I guess I will go without.
