fireguy12117
i scored a plastic upper intake, fuel rail, and spacer from a 95 explorer at the yard this weekend. i want to possibly do some part swapping with what i have on the 93 4.0 which is all stock parts for that year.
i remember seeing a post (correct me if i am wrong, but AllenD) about warm start issues when the weather turns warm in the spring. something about some component of fuel vaporizing out as the heat from a warmed up, shut off motor rises into the fuel rail. when you go to start the truck, it wants to stumble and idle poorly for a few minutes. more annoying that anything else on an older vehicle- however, i did get the most important part it seems with the spacer bushing.
now, can i just swap in that spacer and use the existing fuel rail and upper intake? i ask because the motor the parts came from had EGR where my 4.0 does not. it will require more fabricating to use that plastic intake.
also, does anyone have the part number for the good ford intake gasket? the rebuilt 4.0 came with a felpro kit and i didn't know at the time of assembly that those felpro lower intake gasket suck, so if i am going to do any of this, i'm going to do it all.
