95 ford ranger 3.0l motor swap
cmj31884
I just bought a 95 ford ranger 5-speed with a 3.0l engine, and found out the heads were cracked. i read that there are certain other motors that will work in a ranger. I have not been able to find another ranger motor, but have found a 95 Aerostar 3.0l motor. (which the list said would fit/work.) The salvage yard with the motor and one other place had told me that if i put the Aerostar motor in the Ranger, i will have to change out the rocker arms, oil pan, and various other parts. Does anyone know if this motor will work, and if so what parts will have to be switched out for it to fit? Also, if the rocker arms have to be changed, can you tell me why?
Welcome to TRS :)
No on the rockers
Oil pan and pickup tube for oil pump will probably have to be changed
And upper intake most likely.
Have a read here about the 3.0l changes over the years: http://www.therangerstation.com/tech_library/3_0-build.shtml
Can't speak to exact differences in the 1995 Aerostar 3.0l, it was rear wheel drive.
Ranger 3.0l had a distributor in 1994 and got new computer system and were distriburorless in 1995, so a transition year for Rangers
Aerostar was being phased out starting in 1994, last year was 1997, so may have distributor, but your CPS syncro will fit in it's place.
