Blaynie
- May 4, 2014
Hi guys, I'm new here. I was told this is a good resource so I thought I'd give it a try. My B 2300 has the continuing problem of idling very rough, stalling out as I approach lights and turns, and drinking gas pretty bad it would seem. When the problem began I noticed a vacuum hose underneath the throttlebody had become rotten and fell apart. But after replacing that the problem was not repaired. I've since replaced almost all the vacuum hoses. And yet the problem continues. She'll run fine when you get up to speed. I've also replace the PCV valve and checked that elbow coming from the PCV valve for leaks. I'm just not sure what I'm missing. Any help or suggestions would be appreciated.
