flybeech
- Aug 6, 2013
- Automatic
I've got a very high mileage 1996 Ranger 2.3 MT5. It pretty much runs perfect and I use it regularly for very long trips. It uses a quart every 3000 miles. There is no need to do anything to the truck, but I would like to have a little more punch.
From the various older threads I've seen, it appears the 98-up 2.5 long block, from the oil pan to the cam cover is a drop-in the 95 through 97 models. Solid 2.5 engines are still around cheap and I'm thinking of getting a clean, used 98-up long-block to build while using my truck and dropping it right on in my '96, on a weekend.
My understanding is the oil pan on the '98 model will fit the 97-down frames, without modification, but perhaps looks a little goofy. Can anyone verify? I would prefer to retain the 97-down oil pan,screen and indicator, just to keep it as '96 as possible, but read here that the oil pump doesn't interchange, among other factors. Unknown is if the 2.5 crank, rods and pistons will just drop-in my original 2.3 block.
Am I correct to assume the 98-up 2.5L long-block, stripped of everything, except the oil pan, will drop right in to the 1995 - 1997 Rangers, originally equipped with the 2.3 engine?
