- Jul 20, 2019
- Alabama
- 2.3 (4 Cylinder)
- Tire Size
- 235 75 R15
I'm sorry if this has been covered before. I have been looking for a few hours now and cant find a straight answer.
Can I safely use the the cylinder head from a 1997 -2001 2.3/2.5 Lima engine on a 1994 2.3 Lima block. The head gasket part number seems to be the same but the coolant passages seem bigger on the 1997-2001 head.
I realize that the alternator and ignition coil bracket might have to be swapped to the later style one.
Also, as I understand it, the camshaft gear might have to be swapped for timing marks to line up.
Thank you in advance for any information you can provide.
