Tractor Dan
Went out Monday. Let the truck run for about 30 minutes as it was -35 with the windchill. I at some point don't forget how far in turned on the wipers. They went up to the full left position and stopped. They are stuck all the way to the drivers side. I'm trying to determine if the circuit breaker blew. I tried testing it and set my meter to the amp range of the breaker. I put the probes to it and my meter read 0. It is a 6 amp breaker. I want to make sure this breaker is truly bad before i replace it as it's not a cheap one. $15-$30. Also any other ideas what might cause this if it isn't the breaker? I don't think the arm is froze up as it sat in the sun all day and we got to around 40 degrees. Plus the engine heat as i drove. Need to get this figured out and fixed asap. My instructor for electrical thinks i may have fried the wiper motor but obviously checking the easiest and most likely to fail parts first. Also when i turn the switch for the wiper blades i hear a click under the dash.
