94 Splash Replacement wheels
digitaldog
My daughter (17) has a 94 Ranger Splash 2wd - 5spd. It has custom wheels running a set Futura GLS 235/60R 15 that need replaced. (Shredded the sidewall yesterday) However, I'm not finding much of a selection in that size.
We live in Northeast and I'd like to get her a good set of all-Season radials with excellent wet / light snow traction. I'm thinking to get better tires I need to go up in size, I'm seeing 'compatible' wheels up to 18", but I don't know if these will just bolt on or not.
We're in the middle of buying a new house, so I just don't have a couple grand to throw into wheels / tires & Mods to make the new wheels fit.
Can someone tell me what size wheels will just bolt on, and / or recommend a good tire for wintery conditions.
Did she take out the rim too? I'd just replace the tire if you're on as budget. If you do need new rims get the basic "wagon wheel", "D window" or spoke rims, they come in all sorts of different names, or "modular" wheels (basically the same thing, just a round hole instead of a triangle). Should be around $40-$50 shipped, maybe more depending on brand.
*edit: 5 on 4.5" pattern
As for tire size, try a 215/65R15. Lots more options, a little smaller, but are only .1" diameter smaller (26" vs 26.1"). Which there is a larger difference in a new tire vs a worn out one.
You said it has custom wheels, the only thing would be their width.
235/60R15 recommends a 6.5"-8.5" width.
215/65R15 recommends a 6.0"-7.5" width.
So if they're 7" rims (common) you should be good, but 8" rims are also common. Which may or may not work, the smaller tires get more picky about their rim widths.
And lastly, nothing wrong with a set of stockers (which should be 15x7). Cruise around the local wrecking yards, I bet you can find rims for $30, maybe $20 a pop. Hell, maybe even a decent set of the right size tires too (do check the date code and inspect them carefully).
On a 2wd truck, a 30" tall tire is realistically the largest you're going go. But when significantly altering tire size, remember you need to also change the speedometer.
