I need to find a digram that shows what the different wires go to. I'm trying to install driving lights using a relay so that they only work wen the headlights are turned on.
Why don't you just find the wire at the headlight that powers up the high beam and tie the trigger wire for the relay into that? Whats what I always do at work when I install driving lights. Then use a switch in the cab to complete the ground circuit. Then you can have your driving lights come on with your high beams.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
