Spraying choke cleaner or the like around all vacuum hoses and connections to the upper intake is a good idea to find leaks there. However, the 4.0 engine is designed such that the joint between the head and the lower intake is UNDER the valve covers. Hence, spaying choke cleaner or propane or starting fluid, etc. won't get to that seam, and that seam is usually where they leak. That is why many rangers seems to use oil but you never see any blue smoke or leakage. Oil vapors from under the valve covers is seeping into the intake manifold because the seal has failed. So, if you are satisfied none of your vacuum hoses are leaking and the pipes where they connect to the upper intake are good and not leaking, and your plugs are whitish and not brown, I'd be changing that lower intake manifold gasket, and both valve cover gaskets, since both valve covers have to come off to remove the lower intake. Not a hard job, just takes time. I bought my gaskets at Rock Auto on the web, cheap and good parts. Not only did our ranger run better, fuel economy went up noticeably and less oil consumption after the gaskets were done.
